75" would fit, but I don't know that I feel the need to go that huge.
When was the last time you heard anyone regret buying the bigger TV?
If you think your new TV might be too big you should probably get a second opinion from your husband/boyfriend.A 75" might be too big.
Hahahaha. That was great.If you think your new TV might be too big you should probably get a second opinion from your husband/boyfriend.
I see what ya did there!!!If you think your new TV might be too big you should probably get a second opinion from your husband/boyfriend.
Yeah, the reason I said I'll likely go 65" is because that's pretty much the next size up. My Mitsubishi RPTV is 57". I am not interested in going smaller (which would mean going to 55", which would be quite a bit cheaper). 75" would fit, but I don't know that I feel the need to go that huge.
I'm still a good long ways out, so who knows. If they get used to making large OLED sets and they really come down in price I'd not rule one out.
Yeah, mine may not make it to that point either. I'm still waiting for prices to drop a bit more (I'd like to see a 65" OLED for under $2000), but the way things are, that may not take that much more time. I'm already even eyeballing A/V receivers since I'll need something in the theater room that can handle and upscale to 4K.
Unfortunately, yes. You need HDMI 2.0a and HDCP 2.2.I just realized that if I go 4k I will need to upgrade my preprocessor or not run the TV through it. Right?
All UHD players thus far have dual HDMI outputs so you can run video direct to the display and audio to a non-4K AVR/prepro. The Oppo 203 also includes an HDMI input that can be used for a second 4K source and you'd only need one HDMI run to your display for the two sources (bigger deal for projectors than televisions).
That is only true of disc players. The same does not apply to any of the streaming boxes. If you want 4K HDR from Netflix, Amazon and other providers, you need HDCP 2.2.
Can the Oppo split the audio for a device plugged into the input?
Well, thing is, with a good chunk of the streaming services (at least Netflix and Amazon, the two big ones), if the TV can display such things then chances are you can stream directly to the set without needing an outside device, making HDCP capabilities moot where that is concerned. I'm not sure if there are any OLED displays that aren't Smart TVs capable of streaming directly. If the set will take it directly, I just use it that way.
