Dang. I wish I knew this last summer; I had plenty of time to play and wouldn't have given up on OTA so quickly... :|walls said:Try moving the Mohu up about a foot, like what Batmn said just a couple inches makes a huge difference. Took me quite a few tries to finally find the ideal spot, I actuall run five tv's off that antenna.
Flint said:The HOA can insist you get approval on where you put the Antenna, as long as their recommendation will get the job done they can prevent you from putting up a tower in your front lawn.
Batman said:Interesting, did you enter your zip code at antennaweb.org and see if you're aiming in the correct direction for Fox? ~30 miles is well withing range of a lot of antennas. :think:
walls said:Takes a while to weed through the crap but there is actually good FREE programming, you just have to find it.
heeman said:I spoke to a Tech Support guy at Channel Master today and explained everything that I tried.
He recommended the SMARTenna CM 3000HD. He seemed pretty convinced that this should do the trick, recommend mounting in the attic, but try inside the house first.
$45 Amazon Prime, it will be here on Wednesday.
http://www.channelmaster.com/SMARTenna_HD_Antenna_p/cm-3000hd.htm
walls said:I will start with the obvious CRACKLE. Good channel.
