Maximo
CMonster said:Maximo said:Ok, so long story short, it looks like I need to replace the cable for my downstairs setup.
Do you guys know if this cable is appropriate for running that length?
http://www.monoprice.com/products/produ ... largeimage
If not, what then?
Edit: What about this?
http://www.accessories4less.com/make-a- ... ers/1.html
I would think either one would work. I'll be using a 75' HDMI cable with Signal Booster once my basement is finished. I verified that it worked before running it through the ceiling. I was planning on getting a Monoprice cable with RedMere technology like the one you posted but the length I needed was on back-order.
I will try this because it is cheap and I don't have to run a new cable (which involves taking down my tv). I will report back with the results.
