Good news is I may wind up having a movie poster overlayed on a panel so it isn't just a blank space so design plus functionality
No it will be printed artwork over a panel with same performance as one not printed on.That's a great way to add absorption without killing the aesthetics in the room. Just know that a poster will reflect everything in the treble range while passing sound through in the midrange and lower. As such, don't put a poster over the panels placed at the first reflection points (side walls, ceiling, rear wall).
This will be first reflection point but I wanted something nicer looking than just a panel. Was thinking Waterworld or IshtarOh. that's different. I took the term "overlaid" as to mean a paper poster was being placed in front of the sound absorbing material.
It is still a practical means of improving midrange and mid-bass in a room by putting a 2" thick panel behind a picture frame or poster pretty much anywhere in the room (other than a first reflection point).
You have answered my question. I will have to see how high up the mid is. It is a 2 1/2 way speaker but once a sub is introduced and speakers set to small, the 3rd and lowest driver won't play? ConfirmingI cannot seem to figure out what you are saying about the panel, but the ideal placement of the panel is directly behind the speaker's mid-woofer (whichever driver is operating in the 100Hz to 500Hz range). If you are talking about raising the panel, go ahead as long as it is still behind the woofer of the satellite. Do the same for both speakers.
Paradigm Monitor 9
For above the light switch, I'm a little concerned on hitting the wire when drilling.
Okay, thank youThere are two reflection points on that wall, one for the right speaker and one for the left. Be sure both are thoroughly addressed.
How far back? As much as possible, but not past approximately where your feet/knees are when seated in the ideal spot.
If there's a light switch, and that's above ear level then I won't need above switch, correct?
Below there shouldn't be any wiring correct? First floor and it's a ranch homeYou should be.
Odds are that the box for the light switch and wiring is nailed to a stud right next to the switch. The wiring to the box should be stapled to the stud.
What are you using to hang your panels? A picture of where exactly youre putting them may help.
