-B-
nelmr said:Yesfan70 said:It might be too late for me to post this, but if the 4 Ohm load of the Dyns paired with a Denon receiver worry you, than I would just pick up a cheap amp like the Berhinger A500 from Parts Express. The amp is only about $200.
I've heard that amp with a pair of Dynaudio C-1 bookshelfs, and thought it sounded much better than anything I've ever owned or heard before. Blows my Mackie setup away, imo.
The C-1's are $6500 speakers! I sure hope they sound beter than $1300 Mackies! But from what everyone is saying, not just here, I'm beginning to think that Dynaudio makes some of the most accurate home audio speakers in the world. Judging by the this stereophile article on the C-1s it seems to validity that notion as well.
Regarding the Denon...
Well, I just finished packing the Denon up as the Onkyo came today. I did some comparisons between the two. From what I can tell the Onkyo is pretty much better all around. Here is why I prefer the 708 over the 3310:
1) It supports 4ohm loads
2) Is $50 cheaper
3) Has better bass management options (I can set the crossover on each speaker pair (fronts, center, rears, etc), whereas the Denon was just one setting)
4) Seems to have a slightly lower noise floor compared to the Denon. I hear less hiss when I turn up the receiver when nothing is playing.
5) Sound quality sounds great. As odd as it is, I'd even think it sounds better than the Denon (likely psycho-acoustics).
6) OSD has helpful quick change options (i.e. center channel level, subwoofer level, Audussey stuff if enabled, etc.)
7) Supports HDMI 1.4a
Things I don't like:
1) Doesn't "look" as nice
2) OSD isn't in HD
3) Lacks HD radio.
4) 8-ohm ouput a bit lower than the denon
Those cons aren't really a big deal. The HD radio in the Denon was pretty weak too. The rated power is 110 vs. 120 on the Denon and 0.08 THD vs. 0.05 THD. For 5 channels driven, test results seem to show the difference is more like 85 watts on the Onkyo and 112 no the Denon. This is a 1.2dB difference, so not a big deal. Power consumption is 6.3 amps vs. 7.0 amps.
Other then the listed differences, everything is pretty much the same on the Onkyo. It has networking, same number of connections (minus zone 3 and optical out).
I'm satisfied with the new receiver and feel much better about it than the Denon.
They do, I had them in my home for 2/3 months and still miss them even though my Contour 1.4s are no slouch. Where are you located? If you can go hear a pair. Flint (IG) did a nice review that should be over at the old site.
Glad you like your new Onkyo, you should be plenty happy with it's performance. To me there just isn't another receiver (or the pre) that can compete dollar for dollar. I always found the Denons harder to operate than necessary, I understand the newer GUI is much better, but I have never needed to resort to the Onkyo manual!
