Re: Tried to upgrade to Genie, but Directv talked me out of
I think that was me talking about the self install.
If you're set up with whole home DVR, you likely have something called an SWR inserter somewhere linking all your boxes. You likely also have a box that connects to that SWR inserter and brings your home network in via ethernet. The network signal would then ride the satellite coax to your boxes.
On older boxes (HR20/21 vintage), the network signal would be tapped off the satellite coax at the receiver by a white box and you'd have coax to the sat input on the box and ethernet to the ethernet input on the box. The newer boxes (HR 24/25/pretty much anything recent) don't use that white box. You DO NOT run ethernet to the ethernet port on those units (so the Genie's ethernet port stays blissfully unpenetrated). They get the network signal off the coax- when you do the install you pull out that white box and just run the coax straight to the box from the SWR inserter.
It took me a while to figure out that was why the Genie wasn't showing up on the whole home system. The DirecTV tech I called wasn't any help whatsoever with it. Once I tossed that stupid white box out of the loop everything worked great.
The DirtMerchant said:Just ordered the Genie ($99) to replace one of my HD-DVRs. So I'll have the 5 tuner Genie + my 2 tuner HD-DVR to be able to record 7 shows at once (when the hell is that going to happen). Doghart, I have no idea how you got that all for $49, but they just would not go down below $99 for me. There was an additional $49 installation fee, but I got around that by just having it shipped to me and I'll take care of installation. Hopefully there isn't much to change from existing wiring setup...didn't somebody post about self-install of one of these recently? Anyway...it should be here in a few days.
