You got a lot of nerve calling that a den. I thought a den looked like this...Wardsweb said:Here is my den.
Zing said:You got a lot of nerve calling that a den. I thought a den looked like this...Wardsweb said:Here is my den.
jamhead said:Yup.
Combine this one with his 2 channel and Batman's cave....I'll never post photos of my setup.
What other tools will you be using for calibrating?Wardsweb said:Still need to setup the EV DX-38 to run them active.
These were the last speaker that Paul Klipsch designed (with a smaller horn). The audio engineer( Roy) that worked with him heads the Pro division out of Hope Akansas. The new bean counters at Klipsch were going to scrape this speaker but Roy talked them into letting the Pro department have it. So it is sold mainly for commercial cinema use. These were custom made out of South African Mahogany for home. I still need to make some grills to cover the sides and have the horn painted in a high gloss automotive finish.Botch said:Geez, I've never even heard of those Klipschs; they make that huge TV look... not so huge! :shock:
I'll bet those things will sound large enough for Soundhound!
To start I will be using settings determined by the engineer who helped develop the speaker and researched at the factory where these were built.DIYer said:What other tools will you be using for calibrating?
That is just sick! Yet I just can't stop staring at it no matter how hard I try. If I once said "speakers are not supposed to be bigger than the display", I take it back and I stand corrected.Wardsweb said:The only constant is change. Just got these custom mahogany Klipsch Julibee's today. Still need to setup the EV DX-38 to run them active.
They won't be larger when the projector and drop down screen go in.Zing said:That is just sick! Yet I just can't stop staring at it no matter how hard I try. If I once said "speakers are not supposed to be bigger than the display", I take it back and I stand corrected.
Wardsweb said:They won't be larger when the projector and drop down screen go in.Zing said:That is just sick! Yet I just can't stop staring at it no matter how hard I try. If I once said "speakers are not supposed to be bigger than the display", I take it back and I stand corrected.
jamhead said:They won't be larger when the projector and drop down screen go in.
