Wow, I love the look. I'm sure I can understand the parallel vs in line has bitriometry eventually but the cabinets look cool
Not sure what that word means but perhaps I can help with respect to understanding the differences between parallel and series connections...
Being a mechanical engineer (rather than electrical) I like to think in terms of mechanical analogs.
Instead of voltage, current and resistance of a simple circuit consisting of current flowing through a resistor because of the push provided by a voltage difference, one can think of pressure, flow and ... well resistance through a pipe, where a valve is analogous to a resistor.
All else being equal if I increase the line pressure more water will flow through the valve. I can also open and close the valve to varying amounts, thus changing the resistance, and hence the flow. If I add another valve just downstream of the first one (a series connection) the flow must go through both and the pressure drop across the two is now higher than just across the one, and the flow decreases. The pressure drop across each valve equals the pressure drop across the two together. That's how a series connection works.
But I can also get more pipe and connect the second valve around the first one. Now the flow has a choice of going through either one and as a result there is more total flow through the system. The total pressure drop across the system is less than the sum of the drops across each valve. The flow resistance has decreased in the case of such a parallel connection.
Unlike just about every other piece of math that I faced in university, I found that doing the actual calculations for the mechanical analog much harder than the electrical. Pipe diameters (as opposed to wire thickness) and bends / corners, junctions etc. must be taken into account - and have a much larger effect on the outcome than in the electrical case. Regardless, in the simplified case the mechanical analog does help to explain why a series connection of resistors results in an increase in overall resistance, whereas a parallel connection results in an overall reduction in overall resistance.
