Are those smaller holes going to be ports on the back? They look partially (or completely?) sealed in that last photo...
I like REW more than TrueRTA for a number of reasons; its free, its quite a bit more stable with fewer bugs, it has comprehensive THD measurement capability, it is actively supported and updated (TrueRTA hasn't been updated in something like a year), its sweep function is better and more accurate, it has waterfall decay plotting and many more things that TrueRTA doesn't have. And did I mention its free?Nice just emailed to my self
Ty
By the way, I made a little jig to make the pilot holes for the connectors in the backs of the enclosures so the hole are both aligned center AND they are exactly 3/4 inch apart. That way, if I do decide to switch to proper 5-way binding posts I can use the same holes I drilled for the little bolts.
At a cost of $5 - $10 a piece not sure why you wouldn't go ahead and use them?
So from the looks your also putting a pair of connection on the back for each speaker that would allow them to be wired in various configurations.
Did you mention somewhere how you plan to wire these? It looks like you are wiring each woofer to it's own terminals. You can externally wire them however you want. Any combination of series and parallel.
