OKay, so, um, ...
Um...
WTF?
LS: So let’s put it another way, what would you say is the high level takeaway for what UEF tech does?
TD: It’s a technology that reacts to multiple waveforms: electromagnetic waves, radio waves, and soundwaves. The more things you treat, the better the sound gets. Things such as HFTs, acoustic panels, ground blocks, cables with UEF, etc. all make a difference. You are essentially linking all this stuff together to make a more harmonious whole. If you treat the electrical signal and the mechanical vibrations, you get more harmony and it sounds like live music and less like a stereo attempting to play music that has no resemblance to the space where the original recording takes place. At the signal level, it interacts with the actual electrons themselves. There is a quantum coupling that takes place. I believe electrons can exist in multiple states. They can be chaotic or have more order to their flow, or at least less agitated.
LS: At the factory, you zap your cables with a Tesla coil. Is that what makes electrons more orderly as well?
TD: It creates a pathway for electrons to flow. However, I believe electricity flows as a waveform above the conductor. There is no way electrons are moving through wire like water goes through a hose. No way, no how. The energy excites the electron and it creates an energy wave that rides above the conductor. I don’t believe that electrons flow through a conductor. This is the kind of thing that is debatable among physicists. We are still learning exactly how this works: making observations all the time and then developing theories. Many physicists seem to feel the evidence points to electrons not behaving like water through a pipe. You can’t prove your own existence in the universe. Humans have a need to have easy explanations and often are overly confident in those easy explanations.
LS: You have field generators inside the Synergistic Research PowerCell 12. How does that work?
TD: We are using two fields. We have a DC field and the Earth Schumann Resonance. When you have the two combined the energy is combined.
LS: Tell me more about the Earth’s Schumann resonance.
TD: That was the frequency that we evolved for on this planet. It’s the only RF frequency before modern times. A very, very low frequency wave with one cycle equating to the length of New Zealand. What we are doing is making the predominant RF frequency the same RF frequency that exists in nature prior to radio and all the other manmade frequencies. These unnatural frequencies create tension and anxiety in humans and, left untreated, tension and anxiety in the sound of a stereo. When you replace these with the Earth Schumann resonance, you are replacing something unnatural with something that is natural and that causes you to respond more favorably to music.>>
https://parttimeaudiophile.com/2018/09/07/synergistic-research-powercell-12-uef-se/
