Harmony One
Razz said:
I WANT MY GREEN AND RED BUTTONS!!!!!!!!
GREEN AND RED
GREEN AND RED
GREEN AND RED
GREEN AND RED
GREEN AND RED
GREEN AND RED
GREEN AND RED
GREEN AND RED
GREEN AND RED
GREEN AND RED
GREEN AND RED
GREEN AND RED
Maybe it'd be worth it to pick up a matte or anti-glare universal screen protector kit (think cel phone section at BB) for touch devices and trim it down to fit the touch-screen part. Whatever that material is made out of barely shows any prints if at all...I see these types of kits all the time on buy.com etc...
Does the touch-screen function still work thru this stuff? If so, I'll pick one up tomorrow!
I can't be sure with the Harmony specifically, but they are designed to work with touch smartphones, so I don't see why not. I would look online so you only spend ~$5 instead of $15-20...
The Harmony One's LCD touch screen is pressure adjustable, this way you can set the pressure level needed to activate the touch function. With a screen protector installed, you could set the pressure level to light and not have any problems with activation of functions.
I set mine to heavy, since I find myself inadvertently touching the screen with the light setting and changing functions.
