PaulyT said:Yeah, I know there are workarounds. But my (strong) feeling is I shouldn't HAVE to go through these multi-cable methods just to use a player as SACD only.
Yesfan70 said:Did you see if you can assign an unused HDMI connection to an audio only input, like the CD input?
PaulyT said:.....Anyway, since I'm back to only the PS3 for blu-ray/SACD, it's a moot point for now as there's definitely no way to control that thing without the video on.
PaulyT said:Yeah, that's what started all this - I was investigating a (quiet) standalone player, in large part to be used for SACD playback, where noise from the PS3 is most obvious.
PaulyT said:My current belief is that this is simply impossible with the 885.
Rope said:If your BD player is connected via HDMI to your 885/886 processor, and you turn off the display, this will terminate the HDCP hand shake process and the BD player will also shut down. If you had a dedicated CD/SACD player connected via coaxial or toslink, this wouldn't be the case.
Yesfan70 said:Rope said:If your BD player is connected via HDMI to your 885/886 processor, and you turn off the display, this will terminate the HDCP hand shake process and the BD player will also shut down. If you had a dedicated CD/SACD player connected via coaxial or toslink, this wouldn't be the case.
Sort of off topic, but let's say Pauly has a conventional BD player for a 2nd player and wasn't using the PS3 for SACD playback. Could he still assign an unused HDMI jack on the 885 to the CD input? There is no video signal to begin with that input, so would that still affect the handshake process?
Yesfan70 said:Sort of off topic, but let's say Pauly has a conventional BD player for a 2nd player and wasn't using the PS3 for SACD playback. Could he still assign an unused HDMI jack on the 885 to the CD input? There is no video signal to begin with that input, so would that still affect the handshake process?
Towen7 said:Yesfan70 said:Sort of off topic, but let's say Pauly has a conventional BD player for a 2nd player and wasn't using the PS3 for SACD playback. Could he still assign an unused HDMI jack on the 885 to the CD input? There is no video signal to begin with that input, so would that still affect the handshake process?
There is a video signal, just not from the disc. The player generates a video signal usually with the album, track and timing info. But yes... you can assign an HDMI input to CD but doing so tells the pre/pro that a video source is connected and the HDMI handshake process would be the same (I think).
