nelmr
Okay guys, I went ahead and tried all Q settings, all port configurations, and all valid EQ settings. This comes to a total of 15 different options. Note EQ1 is not to be used with both ports open, otherwise it would have been 18 configurations (3*3*2). I'm using the RS Meter w/ calibration file and an uncalibrated sound card (so yeah not really accurate, I know, but it's all I have). These graphs though can help compare relative differences though.
Below is the first graph (FR response) I'll post in this thread (more to come soon). It is all of the configurations together. It's a bit hard to read, but it should show you the extent one can tune this subwoofer.
I crossed the right front speaker over at 120hz and played a 10-80hz 24 second sweep. This should mostly show output just from the sub. The mic remained in the same location for all measurements on a tripod in the listening position One measurement per configuration (no averaging).:
Here is the phase responses (interesting that they aren't the same):
![15configs.png](http://img252.imageshack.us/img252/2594/15configs.png)
![15phases.png](http://img227.imageshack.us/img227/3459/15phases.png)
