Botch said:I don't have that particular jig, but I do have a biscuit joiner that performs essentially the same function.
The reason I got a pocket hole jig instead of a biscuit joiner is that the screws eliminate the need to use clamps on a glued joint. I don't have many clamps (all five of mine are pictured) so thats a BIG plus. Kreg's literature goes so far as to say that you don't really even need glue but, IMHO, it's a good idea to glue whenever possible. The clamps in the pic above are holding a glued joint that I failed to plan ahead and drill holes for.
