Deleted member 133
Guest
So... still in creative mode...yromj said:Jeff, yeah that's where the "creative" part comes in. For example, to get 4k from a BD player to my projector w/o upgrading my pre/pro I would need two HDMI switches. 1 w/ 1 input and 2 outputs for the blu-ray (1 for video to the the projector, 1 for audio to the pre/pro). The other would be two inputs for the blu-ray player and the pre/pro and 1 output to the projector.
I thought I may be able to do it with a single switch w/ 2 inputs (BD player, output from pre/pro) and 2 outputs (projector, blu-ray source to pre/pro). But when watching a blu-ray, both intputs would have to be active to get both audio and video from the player and both outputs would have to be active to send the image to the projector and the audio to the pre/pro. This would result in two video sources trying to feed the projector.
This all because I don't have an easy way to get another HDMI cable to my projector.
How about this.
I don't currently use it, but I also have a "3 x 1 HDMI Pigtail Switch." Three HDMI inputs and one input. So connect your sources to it. Source selection is done on the device (a button allows you to cycle through the three inputs.)
Then take its output and use the 1 x 2 HDMI splitter referenced above to send the same (both active at the same time) HDMI signal to both the projector and the pre/pro - both of which can be left with the same HDMI input selected for all three devices connected to the pigtail.
