Deleted member 133
Guest
Latecomer (posting) to the thread - although I have been following it with interest.BrianZ said:Barney said:Just wanted to add my $0.02. I also have 20's v2 with an old SVS tube sub like BobR has. Outstanding 2.1 system. Shaking walls etc comes from a good sub that can handle LFE and/or real low hz signals. A great sub will give good clean lower notes, kick drum, etc. not bommie sounds. If no LFE signal...no ground shaking, just clean bass.
thanks, Barney. i know it's a bit of a gamble but i'm gonna take my chances that the 10" Dayton will give me enough. at $400 bones, small footprint and the good rep around here it's too tempting not to try. we'll see.
I've never heard the Dayton, but I do trust Flint's advice (at least on audio-related matters
However, like Barney and BobR I too use an SVS tube (a 20-39 PC+) in a 2.1 set-up. I've played around with five or six types of speaker with it (including a pair of Studio/20 v.2) and if the sound was ever lacking it was never because of the SVS. While your mind is made up, I would encourage others who might find themselves in a similar situation to at least give it a try.
You could also check out my thread on the Chrysalis Photon 10 - which is the sub I'm currently using with the Studio/20's. They still come up for sale (new) on Amazon in the $500 range - but they are getting scarcer. Very small footprint. Very nice sound.
And to be completely silly (at least in some members' eyes) here's a suggestion: pick up a used Yamaha YST-SW160 if you can. (Even Soundhound has used a Yamaha YST sub of that vintage!) The SW160 works very well with the Studio/20's (I know - I've tried it). I bought mine used for for next to nothing ($60 seems to ring a bell) when I was visiting with MattB in Phoenix, and I had UPS pack it for me and I took it home as checked luggage! You might even get away with using the much smaller YST-SW80. (I have one of those as well - currently paired with some Minimus 7s (!) in my dining room) There's one on eBay right now with no bids at $0.99.
Again, this is only for the benefit of anyone else who might stumble on this thread. My point being that there are some perfectly acceptable, inexpensive (perhaps not the SVS), used subs to choose from out there.
