jamhead said:
Thanks Batman. So, using the image height as the limiting size factor for my screen, looks like if I get an 84" 16:9 screen, I'll max out my height requirement when factoring in casing and a 2" border around the visible screen. Looks like most 84" 16:9 screens have a height of about 56" total.
If I use a 2.35 screen, I'll get the same 16.9 size image (about 84") but a much larger 2.35 image.
Is there a downside to using a 2.35 screen? Do you think a PJ like the JVC with zoom memory would be good, or does the picture suffer?
Hmmm, not sure how you're getting to those figures using an 84" screen as an example.
I'm sure the total height including the frame varies a bit from one mfr to the next, but I'm not sure what I'm missing to overlook a difference of 14". I think you could go bigger. What's the total max width you have to play with?
That's a big part of my problem....many manufacturers' sites don't have the total screen dimensions listed. The only one that does is Elite, and I'm not sold on their screens. According to their site, the 84"...total from top of casing including the attachment clips to the bottom of the "weight bar" is 56". For a 92" screen, the total is 62". I've contacted them and they have said the top black border is adjustable from 0 - 6", so maybe that's where they are getting their numbers. A 92" screen with 2" borders all around should have: 2+45 (viewing height)+2+6 (for the casing) = 55"...not 62.
It's going to be tight..as I have (ideally) 54" (which would put the screen right on top of my center and about 1" behind the baffle lines of the main speakers). If I move the screen to 1" in front of the baffle line of my mains, I'll have 56". From an audio perspective, I may be satisfied with having the screen 1" in front of the baffle lines, as the sides of the screen would be at least 12" away from the sides of the speakers. Not ideal, but for movies, I don't think the sound quality would suffer that much.
The only screens I'm currently looking into are tensioned, but I don't know how important that is. Zing's screen is not tensioned, and I don't believe he has any problems. But then, it's a higher quality than what I want to spend, for now.
Width-wise, I have 110" or so between the main speakers, which is plenty for a screen size since I'm only 9ft away from the screen.
Damn...it's always something.
I've contacted Visual Apex just to get an idea of their size in relation to Elite, and he thought the 92" screen "is gonna be real tight".
