SOLD
towen thank you for the info, will buy it right now! *thumbs up*
Good luck guys! I’d be interested to hear about your experience with it.
SOLD
Any idea if I can purchase two Hubs and place one with my main system and one with my bedroom system and walk between both and use 1 remote (and/or smartphone) at either location?
Going to have to look into that.
Up and running in my bedroom. Toshiba tv, denon receiver, DirecTV box, PS4 Amazon Echo. Working pretty well so far. Minor complaints, haven't been able to get the Echo connected, I enabled the skill and connected it to the hub, but Alexa doesn't know what I'm talking about. I'll me with it more tomorrow. I'm sure that will clear up. Other issue is the size of the buttons (especially the #s). Like Trump hands small. And no backlight. Other than that, for $50, really happy. Great recommend. I might possibly purchase another for my main system..but well have to do some comparison shopping for backlighting and larger buttons.Good luck guys! I’d be interested to hear about your experience with it.
... haven't been able to get the Echo connected, I enabled the skill and connected it to the hub, but Alexa doesn't know what I'm talking about. I'll me with it more tomorrow. I'm sure that will clear up.
Nah. You're going to be pleasantly surprised by how easy and effortless it is.Just delivered. Now for the pain in the ass of programming it.
Until he has to go back for the umpteenth time to get things just right. Probably the biggest problem you will have programming Jack, is sometimes things respond a little too much or not enough when pressing a button, and you may have to go back in and tell it to send the signal more or less. Nice thing about Logitech is they tend to walk you through things. I had to use different software when I was programming the 650 versus what I used when programming the One, and I liked the old software better, but that could just be because I was more used to it. Another nice thing about logitech, is that if you get a different remote, you can port your old settings into the new remote, although sometimes custom button mapping doesn't port over with it.Nah. You're going to be pleasantly surprised by how easy and effortless it is.
Can't you program it to do that?Well that was easy, but the remote is useless for me. It won't control the receiver volume while using Roku device. Everything else works pretty well. Oh well I'll be shipping it back.
I did a manual program of the volume buttons and it accepted it but it's not working. The whole Roku interface is kinda shity really. It should be that when I hit the watch tv button it should let me control the Roku but it doesn't work that way. It sets all the inputs and power info correctly but I have to then choose Roku to have control over it. Not so bad but it could be better.Can't you program it to do that?
On second thought I may just keep it and switch back to watch tv to control the volume. I guess that's better then having 4 remotes out.
Thanks Huey, but I did all that. It was actually very simple. All my "activities" function perfectly except the Ruko interface. Even going into adding commands and doing the volume was easy, it just doesn't work. I can live with it but there's no way I could ever expect my wife to be able to do it.Jack, it should control the volume, although you may have to map it in the activity. Basically, there are two pages on setup screen, one for devices, and one for activities. You first setup the devices, and then you create activities using those devices. So for setting up the activity to watch the Roku, you would add your tv, receiver, and roku to the device section. Then you would setup an activity to watch Roku or whatever you want to call it. Under the activity you tell it which tv to use, your receiver controls the volume, etc. And it's under the activity that if you go to the volume buttons on the programming, I think there should be three drop down boxes under in a row, and in the middle box, it should say the receiver is controlling the volume.
