Something others have not asked.  On other speakers we do 1 tweeter to 1 mid.  So the 15 mids to 6 tweeters.  What is the difference and what would be the calculated output.  104 db to 1 watt?  compared tweeter output to mid output.
I haven't done sensitivity measurements, yet. That will come when I am ready to measure the speakers to design a passive crossover (as I have to know if I need a pad for the highs or lows and the amount of dB reduction that pad needs to be designed to do).
But, in general, since I am wiring the speakers in a series/parallel fashion, the power going to each speaker will be significantly lower compared to a single speaker wired to an amp. Since the resulting impedance of my 16 driver array is the same as a single driver (4x4 wiring array), then the output from the amp for a given voltage will be the same power as a single speaker. So, at 2.83V, one watt into one driver will also be one watt into this 16 driver array, so each driver is getting 1/16th of a watt. So, any increase in SPL in the room will be the result of acoustic characteristics of the large baffle.... HOWEVER, there are also rampant nulls and modes caused by the variation in distance from the listener to the various speakers. That means that at low frequencies where the wavelength is longer than the listening distance the output is working in unison to retain the SPL which one speaker would generate. But at midrange and higher frequencies where the difference in listening distance is as great as the wavelength, the comb filtering affect will reduce the overall apparent output in that range.
So, it is quite complicated to predict without some pretty advance software, really. But, when I measure the system at a reasonable listening distance (in this case about 14 feet), the output above 600Hz is about 3dB to 5dB lower than the output below 600Hz. I think I can work with that.
The tweeters, however, I was hoping to get the same beaming effect as the woofers, the same room dispersion characteristics, and a higher power handling solution than a single cheap tweeter could manage. Plus, they just look cool.
