DIYer said:Here are "Hanning" 4096.
Sound card.
Amp at 50W 8 Ohm.
I can but I wanted to make sure I learn the set up and graphs right before moving on to next amp/s.Flint said:Can you easily run the same test on a different amp?
Here is harmonics measurement of different amp (name will be disclosed later) using "Hanning" 4096 FFT at 20W 8 Ohm. No hump at 17KHz but different harmonics. How will this kind of harmonics affect the sound we hear? I'm not sure and I haven't compared it side by side at same volume.Flint said:If the noise at 17k is still there, then it may have something to do with the test setup.
Here is the first amp with "Hanning" 4096 FFT at 20W 8 Ohm. That hump at around 15.9KHz is definitely from amp. Could 19KHz peak be the harmonics of that hump?soundhound said:Now place the top of the graph back at 0dB so the bottom has more resolution.....
DIYer said:Here is the first amp with "Hanning" 4096 FFT at 20W 8 Ohm. That hump at around 15.9KHz is definitely from amp. Could 19KHz peak be the harmonics of that hump?soundhound said:Now place the top of the graph back at 0dB so the bottom has more resolution.....
DIYer said:How will this kind of harmonics affect the sound we hear? I'm not sure and I haven't compared it side by side at same volume.
How long should I run the measurement? The graph seems to flatten out between harmonics when it's run longer (>5 sec).soundhound said:BTW, either both these amps, or your interface is pretty noisy.
DIYer said:They are both transistor P-P amp. The second amp (blue) somehow shows more of second harmonics despite its harmonics out to high frequency. That second harmonics would mask the following odd harmonics I suppose.
DIYer said:Here are the names of these amps.
Blue plot: QSC RMX850 rated at 200W @ 8 Ohm (pro amp transistor P-P), MSRP $350. I use it for surround sound.
Green plot: Audio Source AMP100 rated at 50W @ 8 Ohm (consumer amp transistor P-P), MSRP $100
Yellow plot: Dynaco Mark IV rated at 40W @ 8 Ohm (tube P-P amp), MSRP $400 - 450.
White plot: Tubelab SE rated at 7W @ 8 Ohm (tube SET amp - diy), cost: $350 - 700.
Purple plot: Ashly SRA-120 rated at 45W @ 8 Ohm (pro amp transistor P-P), MSRP $550 - 700.
Does it have something to do with bias voltage? I have it set at 1.1VDC instead of standard 1.56VDC. I've read it somewhere that the original design was made when typical residential wall outlet was supplying around 115VAC 40 years or so ago.soundhound said:I think the high noise floor of your interface is obscuring most of the view of the distortion products. The Dynaco MkIV is a bit surprising because the sidebands on the sides of each distortion product is intermodulation distortion (IM).
DIYer said:Just tried the other sound card and it's no better. I wonder if being USB external sound card has something to do with it. I'll just have to live with it for now.![]()
