I know they prefer the IB sub to my drummingHis neighbors love that IB sub!
Gotcha, yea when I said "2.1" I kind of meant crossing over the L/R channels to the sub, but I realize that wasn't clear from my post haha. Glad to hear you'll still be using the IB subs, as those are amazing!Of course I will! That's the best sub bass I've ever heard indoors. But, they will be incorporated into the main speakers, not treated as a separate .1 channel.
The Sub-Frequency Bass mounted in an infinite baffle situation. Along with the DSP for the crossover and time alignment. Assumed.
 Okay... so here's what I am talking about when it comes to simplification of my rig.
When I complete my new two channel system (no surround), this is what it will look like:
Look at how simple that's going to be. No more IR extending wires and gear, much less power routing and conditioning, and a much simpler 12V triggering system. In total I am going from over 30 power outlets to a mere 12 outlets all located in one area. The remote needs are also going to be significantly simplified.
I cannot wait.
Curiosity is getting to me haha, so a few questions, but if you're starting a new thread you can hold off on answering these -
Is the rendering of your new speakers accurate or just for illustration purposes? More specifically are you going with an MTM layout again for the upper portion of each speaker? I remember you were wary of the cost (understandably).
Also are you going with two woofers per speaker this time (not counting the IB subs)?
Also I know electronics are generally a very low priority, but based on some recent threads / discussions, since in general your room and speaker designs are dialed in extremely well, it sounds like you're at the point where you do take into consideration the performance of the electronics you're using?
I'm not sure if this is helpful or not, but I found this thread where measurements were taken with the miniDSP 2x4 HD, which I know is a different product than the 4x10 HD you mention, but it may give a clue on performance? It's unlikely the "doesn't match the best-in-class" performance of some of the measurements would be audible, so this might be a discussion in academia rather than real world performance... (for the cost, it seems like an excellent product):
https://audiosciencereview.com/foru...urements-and-minidsp-2x4-hd-dsp-and-dac.2674/
Here's another site that has measurements of the 4x10 HD, but I haven't had time to review / absorb the results very well yet:
https://www.neurochrome.com/minidsp-4x10-hd/
Gotcha, glad to know the MiniDSP performs well enough with those added features. I too like the idea of staying in the digital domain from the CD player to the MiniDSP for crossover, etc, purposes. When we met up I had asked if you had any concerns about the multiple DAC -> ADC -> DAC conversions of your current (now previous) setup, and you didn't, but it seems like staying in the digital domain for as long as possible simplifies thingsI've seen professional lab tests for the MiniDSP products and they perform on par with most high-end digital products. There are lower noise products out there, and they could be important, but in this case the benefits of the active crossover circuit, low-ringing digital EQ, phase compensation, and delay adjustment provides vastly more benefit than something like a slightly higher noise floor (which I can compensate for using careful gain adjustments of the system through the gain control on each amp).
Basically, what is the weakest link in my system? It is by far and will remain by far the speakers followed closely by the acoustics. These new tweeters can brag to have extremely low THD with perhaps the lowest 3rd order harmonic distortion measured from a soft dome tweeter, but at 94dB SPL at 1 meter it is still below 0.4% - a shockingly low level, but orders of magnitude higher than the MiniDSP or amplifiers.
But, your initial question is worth considering: If I have the best speakers I can attain and the most ideal room acoustics I am capable of installing, when do I start looking at higher end electronics? Well, I am. The MiniDSP is significantly better than my old Behringer DCS2496, even the modified version I used for my stereo channels (I replaced the output section with an upgraded system and replaced the system clock with a better module). I am removing the active preamp entirely. I am going with a single amplifier for each loudspeaker transducer. Overall, the electronics are being upgraded across the board. I am even bypassing the DAC in the CD player and remaining digital from the source into the digital crossover.
So, this upgrade is about more than speakers already.
And... I will add, the review and testing for the MiniDSP 2x4 HD is stupid. He was tainted from the beginning and I don't trust a word of it. Even his measurements don't compare reasonably well to the industry measurements I've seen. I think he either has no idea how to use his test gear, or he wanted to write a bad review from the beginning.
Was there anything obvious about the way he did his measurements that indicate how he might not have set up his test gear properly? Or are the results just way off? One of the issues with the audio industry is measurements still aren't very common, with Stereophile and a few blogs carrying the load. So it's a let down if measurements aren't done in a meaningful way.
