Babs
Queen "B"
saldog said:ba-ZING-a
^ HA! The bookshelves add such a nice touch. Nice job, Chris.
Your entire project looks incredible, Mike! Nicely done. Hello to Renata!
Wardsweb said:Excellent job! You could always paint the wall plates below the screen the wall color.
Flint said:For the most impressive stereo performance, you should focus on Symmetry - it is the Lord God Master of stereo imaging.
So, if the ceiling panels cannot be centered, you may be better off making them smaller so they are balanced between left and right.
Also, for the Soffit, a thin 3/4" panel mounted directly to the ceiling is better than nothing. You do lose a little height, but it isn't the end of the world. You could get some thin compressed fiberglass panels and mount them flush against the ceiling where the soffit is then let them extend out into the room where they are separated from the higher ceiling. You could even place some other panels on top of the ones which extend from the soffit to get the most of the opportunity.
As for the side panels, that may be more than you need. I would look into using some geometry to specifically address first order reflections for each seating location and nothing else. Then, spend the rest of your acoustics budget on bass traps.
saldog said:Thanks for the compliments, guys, and the suggestions, Flint. You are right, i could do a 1" on the soffit.
How's this look? Green dashed line is the room centerline. The tan rectangle is the trim between black/white ceiling, so a panel can't go across that.
I did a little geometry and that covers all 1st reflection points for the front row, and most of the second row. The cloud covers all 1st reflections for the 1st row couch. And it's symmetrical!
Are the ones behind the speakers less important? Those seem to be recommended often on AVS.
