I have a significant null at 80 and 90 Hz, the rest of the low end is pretty even.
I will try moving one of the subs next weekend.
So far, it is great!
Remind me of the depth of the room?
That's not too bad for long term test tones. Tones like that enhance the resonance. Can you perform a quick sweep?
Also, if 90 hz is a real standing wave null, testing 45hz should show either a null or node. You could also test 135hz to understand 90 hz better.
^Have you also experimented with different crossover points? I dramatically reduced a null I had by setting the XO to 90Hz from 80Hz.
