PaulyT said:Can you put some sort of thin wedges - shims maybe? - under the speaker that needs to tilt down more? As long as you're going to screw the speaker to the mount anyway, it would still be stable, and could give you a more optimal angle.
PaulyT said:Those drywall anchors are interesting... might have to try those someday. I have plaster walls which are very crumbly, and the usual plastic anchors don't always work all that well.
You can also get a speaker wire that's very wide but very flat, it just adheres to the wall and you paint over it, I think Parts Express offers it.Towen7 said:So what I'm going to do is run power and audio cables through a thin plastic channel attached to and painted to match the wall. It should fit in the space between where the ceiling starts to slope and the wood moulding. I'm hoping that it won't be too ugly.
Botch said:You can also get a speaker wire that's very wide but very flat, it just adheres to the wall and you paint over it, I think Parts Express offers it.Towen7 said:So what I'm going to do is run power and audio cables through a thin plastic channel attached to and painted to match the wall. It should fit in the space between where the ceiling starts to slope and the wood moulding. I'm hoping that it won't be too ugly.
heeman said:Lookin' Sweet...............Nice Job!!!
What speakers will be mounted on the AM-40 Stands? I am also considering some kind of wedge to give mine a little more downward angle also. I had to make the same decision about a little forward or back quite a bit. Chose back because this is a feakin' living area not a dedicated room.
Keep up the good work! :eusa-clap:
AndySTL said:I haven't posted on this thread but I have been following it. That is one sweet looking room. I'm jealous. How long until you think it will be completely done? Can't wait to see the final pics.
