AndySTL said:
Yesfan70 said:AndySTL said:
Not too bad. I wonder how much those stands cost.
Wished I had the coin for them.
Ah, like what happened to the coin from the sale of 7 Mackies? And don't tell me you spent it on women and whisky.
Barney said:Just make a note.....our v2's are rear ported.......the v5's are front ported.
Randy said:I had noticed that in the past. I wonder what Paradigm's motive was for moving the port from the front to the rear?
Huey said:Randy said:I had noticed that in the past. I wonder what Paradigm's motive was for moving the port from the front to the rear?
Repeated(i.e. thousands) of requests by Matt B., as he had grown tired of unhooking the wires! :happy-smileygiantred:
Bob R said:-B- said:Bob, minwax has a red mahogany in the standard stain and a rosewood in the water base. Either one will be a close match to your speakers. Use a SATIN finish polyurethane over it and your set. Remember, prep is key. I used the water base, less stink and just as durable.
Thanks -B-
Did I ever tell the story of when I polyurethane coated a set of stacking tables? I kept getting bubbles in the finish and had to sand and repeat. After seven coats I go to the paint store and start to complain.
Paint store guy:
Did you shake the can?
Me:
Yup
Paint store guy:
Don't do that!
:naughty: :naughty: :naughty:
Orbison said:Some people say it allows the speaker to be placed closer to the back wall without affecting the sound...
Flint said:.....A rear port is, generally, a much better performing option.
Yesfan70 said:Flint said:.....A rear port is, generally, a much better performing option.
Because it's away from the listener and not pointing towards them (port noise)?
That's how I have always understood it.
