				Huey said:
			Jeff,
Are doing 2.1?  I know you aren't going to use the svs speakers on a permanent basis, but do me a favor and try running them full range and pull the plugs out of the ports if you are using them.  I find that with 90%+ of music that a sub is overkill, and most music sounds better with the bass coming from the speakers.  Either way congrats on putting together a music only system.  I have contemplated doing just that with B&W's, just haven't found the right spot yet.
BTW, do you feel the Outlaw is more musical than your previous receivers?
I have been playing around with 2 vs 2.1.  The BIC sub I am using is not that good so for right now it is 2.0.  After initially trying the plugs when I first got the SVS I I have run them without the plugs.
And definitively the 2150 has a more musical sound.
Everything is connected via analog no digital optical or coax.  Very good sound stage.  Everything I expected.
The problem with that, is that the source is the dac and not the receiver, which isn't really a problem, although the Outlaw will probably have just as good dac, if not better than the source component.  Not a big deal either way, but I would try a digital connection just for ease of setup.  Have fun!
